Old 01-16-2005, 03:22 AM
PA93 PA93 is offline
PA93 remote entry & heating problems
Hello!
My father has just bought PA 10/93 with only 88k miles on it(orginal). Engine runs perfect, transmission works good too. It has full optional equipment except sunroof. What do you think about it?Is it a good car?
I've got 5 questions:
1. There is a light "TRACTION OFF" - it lights only when I start the engine and goes off after maybe 2 seconds. Does it mean that my PA has Traction Control System?In car without TC is that lamp present too?
2. We've got problems with heating - it doesn't matter which mode I select on ComoforTemp there is no warm air from panel outlets only from floor outlets and/or windshield outlets. What's wrong with it?
3. Remote entry doesn't work I've changed the batteries, I did a connection between A and G in the connector near break pedal (pdl did lock and unlock), i've pushed UNLOCK on remote pilot and nothing has happend.Afaik sth is wrong with front passanger door's keyhole and sth was disconnected but power door locks closes this door.
4. Is it possible to connect CD changer to Delco AM/FM/Casette with Concert Sound II?
5. And the last one - Is there big difference (technical) between PA and Lesabre?I know that PA is bigger but isn't PA just bigger and more luxurious version of Lesabre?
Anyway car looks great and especially here - in europe turns heads
Sorry for my poor english
Best regards
PA93 owner
Old 01-16-2005, 07:11 AM
deadring deadring is offline
Re: PA93 remote entry & heating problems
Originally Posted by PA93
Hello!
Best regards
PA93 owner
ok well for question 1 , that would be normal that it lights up at startup a bit..and yes you must have traction control.. since the light goes on.
question 2 normal, i have a 92 and its the same, the ONLY way to get air to the front is when you use the air conditining, OR you ask for a COOLER temperature than the one in the car. otherwise, you get floor outlets and/or windshield outlets.
question 3 now thats a problem.. electrical maybe?
question 4 if you buy one that emits at a certain frequency on the FM range, the ones that dont need to plug wires to the radio cassette, yes you can.
question 5 practically the same car, but on a bigger body. same lights, same engine/trannsmission and electrical .. GM does not reinvent the wheel for each models.
why do you europeens like american cars and not buy a beemer ( BMW) which are cheaper, have more spare parts available ( more than here anyways) and out performe the handling and top speed or a PA ? unless it is the luxury you seek.
dont worry at my age, i get looked at funny too in a car like that.
deadring
Old 01-16-2005, 12:34 PM
yogi_123rd yogi_123rd is offline
If Re: problem2: Engine vacuum actuates the valves in the vent system. There is a small vacuum hose that goes to a spot on the engine firewall just below and to the left of the master cylinder. If it's off (it could have dryrotted off), air just comes out the defroster and heater vents.
