Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-16-2005, 01:11 AM
vbeurotuner204's Avatar
vbeurotuner204 vbeurotuner204 is offline
Send a message via AIM to vbeurotuner204
Turbo Question
Ok guys sorry for this, I'm probably gonna get tore up over this one, but here goes. Whats the difference between a blow off valve and a wastegate?
'97 GS 420A 5-Spd
Cold Air
Cat-Back
Plugs/Wires
Ball Bearing Shift Linkages
Coil overs and 17's
Old 01-16-2005, 02:00 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Turbo Question
SEARCH before you post next time!!!
Wastegate (WG) allows exhaust to escape the turbine housing so the exhaust doesnt keep spooling the turbo and it isnt building boost past a certion PSI.
Blow off valve (BOV) releases pressure from the intercooler and intercooler pipes when throttle body plate is closed. When the throttle body opens the BOV closes allowing you to produce boost into and through the manifold. But as soon as the manifold sees vacuum (throttle body closed) the BOV opens releasing all the boost that you were currently building.
