Originally Posted by karenk
PLEASE HELP
WE just put a used fuel pump on that wasnt the problem, what can it be?
I am not amy expert on cars, or aerostars but maybe my 2 cents worth will trigger other posters. Our 94 saturn was running rough, choking at higher speeds, and beginning to not shift (spinning without shifting). and less power. A few episodes we just crawled at 10 mph, after parking with engine off, we could restart and drive again. Finally the car wasn't shifting and died with a loud horrible klunk as we drove it in low gear to the trans shop. They found we had a bad alternator. They said transmission etc can't work with bad alternator. Replacing the alternator fixed it. So it couldn't hurt to check your alternator. Trans people said the bad alternator was not healthy for the trans either. Good luck.
p.s. we had a problem a few years ago where the engine ran hot, oil was dirty, car ran ok until 45 mph, where it would choke and run rough. Replaced ERG valve. No change. I heard car guys on radio suggest checking out the exhaust back pressure if erg wasnt the problem. That gave me idea maybe my catalytic converter was clogged. Found out our model was rated for 70,000 miles. We put in new catalytic converter, and problem went away engine ran cooler, and oil was not longer black tar. But that problem did not involve transmission)
