Old 01-15-2005, 09:41 PM
cokekid cokekid is offline
service engine soon light on 88 cherokee
how do i get it diagnosed? there is no way for me to know what goes wrong.
Old 01-16-2005, 05:06 AM
Cam7 Cam7 is offline
Turn the Key on then off then back on again. Your service engine light should flash to tell what code it is.
Old 01-16-2005, 10:53 AM
xj31 xj31 is offline
Re: service engine soon light on 88 cherokee
its a maintenance light,not check engine.its turned on by a timer under the dash.that system doesnt store codes.to turn the light off,just unplug the timer.its under the steering column.its a semi transparent box with a bunch of white plastic gears inside.
Old 01-18-2005, 07:23 PM
so this jeep doesn't have a service light!! it doesnt have an OBD.. but it does have the two plugs outside under the hood can i buy something to check it.
Old 01-19-2005, 09:23 AM
JUSTJEEPS JUSTJEEPS is offline
Will not set codes,you can read certain systems but its very limited.
AT JUSTJEEPS WE REPAIR JEEPS FOR A LIVING,NOT FOR FUN.
Old 01-22-2005, 06:00 PM
there is a tool called a drb 2 that works on that.it can do system tests and at the end of the test it will say either no faults or it gives you a code with no description.
Old 01-22-2005, 10:55 PM
where can I find the (drb2) tool at
Old 01-23-2005, 10:59 AM
Saudade's Avatar
Saudade Saudade is offline
Here's one for auction ion eBay.
http://tinyurl.com/44wa7
