Old 01-15-2005, 09:37 PM
91CivicDX 91CivicDX is offline
How Do I Adjust My Air-fuel Ratio??
I just installed a cool air intake and will be installed headers/exhaust soon and i know that my cars ECU still thinks it has the stock air filter, etc. and i know my mixture(A-F Ratio) will be off and i want to know how to adjust it so my mixture isn't too lean or too rich. Do I need to adjust the fuel pressure?? Is there any chips I can get that would make my car run faster and if so which chip would be the best for my civic. Thanks
-Glenn
P.S. Where is my cars ECU located??
Blue 1991 Honda Civic Dx 4 Door
1.5L 4 Cylinder
AEM Cool Air Intake, AEM Fuel Filter, Bosch Platinum Spark Plugs,
Nology Wires, Ichibahn Shifter.
Old 01-15-2005, 10:33 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
the ecu is under the passenger side capet, close to the firewall.
88 civic dx
Old 01-15-2005, 10:44 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
Re: How Do I Adjust My Air-fuel Ratio??
you can go and reset your ecu
Old 01-15-2005, 10:45 PM
And how do I do That??
1.5L 4 Cylinder
Old 01-15-2005, 11:02 PM
2ndb18's Avatar
disconnect your ground on your batter, or take the hazard fuse under the hood out for a lil bit.
88 civic dx
2CrX's Avatar
2CrX 2CrX is offline
pull the ecu fuse in the engine compartment and let it set for a minute before plugginf it back in. But if your 02 sensor is working properly, your air fuel ratio should be fine.
Old 01-15-2005, 11:04 PM
vladlos's Avatar
you can pull the hazard fuse for 20 seconds or so. its found under your hood. 15 amps i think?
OR
you can go and disconnect your whole battery from your car for like 10 minutes or so according to other sources.
then start up your car and let it sit at a steady idle for a few minutes.
Old 01-16-2005, 12:01 AM
KrisSmithRocks's Avatar
KrisSmithRocks KrisSmithRocks is offline
Send a message via AIM to KrisSmithRocks
yea your O2 sensor is what controls the A/F ratio after it heats up to operating temperature, you shouldn't need to reset your ECU.
89 Honda Accord LXi 2dr- Daily driver SOLD (sniff sniff)
89 ED CRV... soon to come GSR head, ARP studs top and bottom, T3/T4 at about 6psi ... it's quick...
89 ED DOHC ZC
Old 01-16-2005, 12:18 AM
Kven's Avatar
Kven Kven is offline
boltons wouldnt really throw off the a/f mixture.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 01-16-2005, 12:55 AM
2CrX's Avatar
^^^ Yup
Old 01-16-2005, 09:29 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
I've heard Doritos work wonders.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 01-16-2005, 10:00 AM
doug294 doug294 is offline
Send a message via AIM to doug294
Yeah don't buy any of those stupid e-bay chips they will advance your timing and cause nothing but problems. I have a friend that can burn a real chip if you would like one. e-mail me at [email protected] with all your complete motor setup and add ons.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 01-16-2005, 02:02 PM
Hybrid1990crx's Avatar
hit your positive terminal to your negative for like 3 seconds and that will reset your ecu.
Old 01-16-2005, 02:47 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: Re: How Do I Adjust My Air-fuel Ratio??
.....brilliant
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-16-2005, 03:33 PM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
You can buy an aftermarket fuel pressure regulator and increase the pressure 3-5lbs. It will richen up the ratio a little but it may not make much difference in power. Not that you can feel anyway.
90 Civic Si Turbo ZC
