Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-15-2005, 09:16 PM
5gcivic's Avatar
5gcivic 5gcivic is offline
No.1 Misfire Bad Injector?? JDM Engine Help
I have a d16z6. I replaced all the plugs, wires, control module, cap, and rotor last night. I just drove it for about a mile and it still runs like crap. No. 1 cylinder misses at idle and when I hold the Rpm at about 2000. I pulled the no.1 spark plug and it is completely black. Pulled the rest and look fine. What could be causing this? Do I have a bad injector that is staying open(running that cylinder rich) or could it be a wiring problem to the injector? Please let me know. Thanks
Nick
Old 01-16-2005, 02:56 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
well, you just stated yourself what might be the problems. So why not test the injector to see if it's faulty first? if not then start tracing the problem back from the wiring. you will need a wiring diagram, I don't know if it is the same as the non-jdm lay out so you will have to do some more reseach on it.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 01-16-2005, 04:10 PM
5gcivic's Avatar
Re: No.1 Misfire Bad Injector?? JDM Engine Help
Ill see if I can get a scope on it this week to see whats goin on. If you have any other suggestions let me know. Thanks
Old 01-16-2005, 09:27 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
if your injectors test fine, then check continuity on both wires.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-16-2005, 11:38 PM
5gcivic's Avatar
thanks for your help. Ill look at it tomorrow and let you know whats goin on.
Old 01-17-2005, 01:46 AM
AF - Advisor
dont forget to measure resistance of the injector with an ohmmeter
Old 01-18-2005, 12:43 AM
civicnation425's Avatar
civicnation425 civicnation425 is offline
Send a message via AIM to civicnation425
Re: Re: No.1 Misfire Bad Injector?? JDM Engine Help
i had the same problem, ended up just a thread problem and my plug didnt get all the way down. it created a similar problem. not sure if its the same as you but, im just throwing out a similar circumstance.
1995 Civic EX
AEM RAI
Magneflow Catback
Plugs/Wires
Coil-Overs
Just the basics...
Old 01-18-2005, 02:47 PM
5gcivic's Avatar
Do you know what the resistance should be? Civicnation what do you mean by a thread problem? Thanks for the help
Old 01-18-2005, 03:59 PM
AF - Advisor
between 10-13 ohms.
Old 01-18-2005, 04:10 PM
Re: Re: Re: No.1 Misfire Bad Injector?? JDM Engine Help
cross threaded, it doesnt allow your plug to go all the way down. i think we have all had this happen in one end or another, if you look at the plug and half is black instead of just the tip if could be a thread problem, or if the other end of the spark is all black from exhaust then that could also be it.... chech the thread of your plug real close if it all looks legit then you are prolly fine...
it would feel like you torqued it all the way down, even though you might have only went a 2/3's of the way.
1995 Civic EX
AEM RAI
Magneflow Catback
Plugs/Wires
Coil-Overs
Just the basics...
