Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-15-2005, 07:41 PM
Towlie's Avatar
Towlie Towlie is offline
Send a message via AIM to Towlie
Need help, axle/hub
ok so let me start at the top
wheel bearing went out, and i replaced it
and everything was fine, when i went for test drive, the axle nut wasnt tightened all the way so we had to re tighten it
than everything was fine
ran for a bout a week
and the nut came loose slowly
and the axle would just spin in the hub
so i tightened it up
all good for another week
than last night on the way home from work
feel loss in power and weird scraping like noise like it the axle nut was loose again
smoke everywhere
so i pull over
and sure enuff its loose again
but i had no tools
so after waiting from midnight to 4am for a tow truck i brought it home
and i put a new axle nut on that i already had and tightened it and it drives just abit
but its like i cant tighten the nut enuff to keep it from spinning
im thinking that
either the hub assembly and wheel bearing isnt compatible with the axle
i believe the one i got had no ABS
and my car is ABS
im wondering if that eve n matters
So QUESTION ONE: Are the parts compatible
and QUESTION TWO: what could be wrong
i notice theres not carter pin to keep the axle nut in place
am i doing something wrong
and QUESTION THREE : what could of been damaged from this?
Wanna get high?
Dont forget to Bring a Towel!
Towlie is off the wang wang!
Asshole Krew Member #004 We are 1337 RoXxoR and OWN JOO!
Old 01-15-2005, 11:02 PM
Towlie's Avatar
Re: Need help, axle/hub
anyone?
Wanna get high?
Old 01-16-2005, 01:04 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
sorry, i'm the busyest on weekends
1. to clearify, what all did you replace? bearing, hub, CV joint? new or used? your year and year of donor?
2. one of two types of nuts may be used in a case like this. and i'm not sure of the spelling on ether. one is a castlelated nut, this is the type used with a cotter pin. and if you see one wou will know it, it looks like a castle tower. the other is a interferance fit nut, one time use only, its designed to fit real snug on the threads. to the best of my knowage all years S-series used the interferance nut on the CV joint. a normal nut can not be used, get this nut from the saturn dealership. wishful thinking says fourth time's a charm. but just in case, use blue locktight, confirm with saturn that locktight can be use on this nut first, i'm not sure if there is something special with the interference fit.
3. thats harder to say, but smoke is not good. i hope you didn't fry the new bearing, i suggest you take it all apart again(sorry) and check everything with a fine tooth comb. check every peice is in place, use the opposist side for referance. for example i know there is a washer behind the axle nut thats easy to over look.
after that, you may want to post on saturnfans.com
Old 01-16-2005, 02:42 AM
Towlie's Avatar
thanks, yea im guess the wheel bearing could of been fuked over, im not sure
but i replaced the hub bearing assembly all as one piece, my car is a 93 sc2, and i think it came off a 92-93 sc2, my friend mentioned to use locktight, so maybe ill try that, but as far as taking it all apart, eh i dont think id know what i was lookin for, so eh, i dont know what im gonna do with this
Wanna get high?
Old 01-16-2005, 04:03 AM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
locktight would work... its just a pain in the balls to get it back off if you ever need it again unless you have air tools
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-16-2005, 02:53 PM
i don't see any differences in 92/93. but if it was used.....
i mean looking for uneven wear, bends, cracks, shinny/polished areas, ect.
Old 01-16-2005, 04:37 PM
Towlie's Avatar
ok so i think my problem is that, the whole assembly that i got from the junkyard was non abs, and my car is abs, and i guess the axle and everything wasnt compatible, and it grinded it all up, so im guess i need to replace the axle and the whole wheel bearing assembly? im not sure, i need to find a mechanic to look at it in my area, but all are pretty busy
Wanna get high?
Old 01-16-2005, 04:39 PM
Towlie's Avatar
i got the axle on so tight now it wont come off, i didnt even use locktight, but now theres like a scraping noise type thing going on, i think the wheel bearing got fucked up, and thats what the nosie is from
Wanna get high?
Old 01-16-2005, 06:00 PM
is it a constant sound?
Old 01-16-2005, 07:18 PM
Towlie's Avatar
yeaaaaa,
Wanna get high?
Old 01-16-2005, 10:39 PM
nope not a bearing... they dont scrape
they make a droning sound and get worse with higher speeds
Old 01-16-2005, 11:45 PM
Re: Re: Need help, axle/hub
towel, what state are you in?
ABS vs. non-ABS would be a issue, i don't know about the kuncle, but the ABS CV joint has a sensor ring. but i don't see that smoking. the ABS sensor has a tight clearance of about 0.040" IIRC, i wonder if it hit some thing.
good point, if the sound is not related to speed, then that leads to a non-rotating suspention part, tie-rods, struts, ect. i would not be surprized if a blown strut would smoke. you should also be able to see oil leaking from the strut.
Old 01-17-2005, 12:50 AM
Towlie's Avatar
yea wlel there was grey grease scattered everywhere with what looks like tiny particles of metal in it
Wanna get high?
Old 01-17-2005, 01:18 AM
Towlie's Avatar
oh and im in FL
Wanna get high?
Old 01-17-2005, 09:02 AM
mmmm thats not good
