Old 01-15-2005, 07:13 PM
99intriguePA 99intriguePA is offline
no low speed on blower
My '99' intrigue's blower motor won't work on low setting. It works on all other settings. It had been making a rubbing noise on low for a while but when it was turned up the noise went away. After it quit running on low I removed the motor, took it apart, and greased the bushings - no more noise but it still won't work on low. Any ideas?
Old 01-15-2005, 11:18 PM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
GM had a problem with the fan resistors burning out on some of their late model cars. They designed a new part for it. My problem was it would work on the high setting but not at all on the others. The resister assembly is to the left of the fan motor up against the firewall inside of the ductwork. You will probably have to lie upside down for this. I ended up having to leave one of the screws out when I put it back in because it is so close to the firewall.
Old 01-16-2005, 07:57 AM
Burnout524 Burnout524 is offline
Re: no low speed on blower
How much does this new part work. It seems like my car has the same issue; it's making the squeeking noise on low, but there is acually heat output so it sounds like my fan resister is going to go.
Seems like were getting a lot of HVAC problems lately, eh?
'99 Olds Intrigue GX
Old 01-16-2005, 09:12 AM
You wouldn't happen to know the part # of the new resistor?
Old 01-16-2005, 08:39 PM
Re: Re: no low speed on blower
The reciept is in my tool box. I got the resistor from the GM dealer. They should know what it is. It is a pretty common problem
Old 01-17-2005, 12:52 AM
Re: Re: Re: no low speed on blower
have to look into getting a resistor.
Thanks to all
