Old 01-15-2005, 07:52 PM
acoustic-sounds acoustic-sounds is offline
DISTRIBUTOR ( spark-plug wire order on distibutor for each cylnder-1234)
What is the order the spark-plug wires go on the distributor starting from 1-2-3-4 its for a d16z6 vtec. If any one has A diagram that helps to. PLEASE IF YOU KNOW LET ME KNOW THE ORDER ON THE DISTRIBUTOR THAT THE WIRE GO FOR EACH CYLNDER 1-2-3-4
Old 01-15-2005, 08:07 PM
BullShifter's Avatar
Re: DISTRIBUTOR ( spark-plug wire order on distibutor for each cylnder-1234)
If you just replaced the cap, next time leave the wires attached to the old cap so you know the order or mark the locations before beginning.
here's a diagram - http://www.binghamtonlife.com/manual...s/91-23-60.jpg
This shows which cylinder is which http://www.binghamtonlife.com/manual...es/91-6-30.jpg
#4 closest to distributor, #1 closest to timing belt, #2 #3 are common sense once you know one of the locations
