Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-15-2005, 06:31 PM
ford8n ford8n is offline
Question Kicks down to easy
I have a 1988 ford bronco with a 5.0L. I have a 8 inch lift with 35's.Got headers flowmasters and K@N air filer for mods.I realize it is kicking down because of mostly tires and maybe the lift. What is does is when I drive down the road in a low RpM it starts to lose speed and then when I press the pedal a little it kicks down. This is effecting my gas milege when it keeps going to different RPM's all the time. What you think can be done to stop this.
Old 01-25-2005, 06:52 PM
dxrflyboy dxrflyboy is offline
Re: Kicks down to easy
The only real solution is to gear your truck down. The big tires effectively gear your truck higher. You will have to change the ring & pinion sets in both diffs.
