Old 01-15-2005, 04:41 PM
tdinitroxdiver tdinitroxdiver is offline
No electrical power...
Hello I'm new in the forum and my 1995 Windstar when i open the door the dome lights will not work. Key in the switch and no electrical power, no gauges, no radio, nada!!! like a dead battery but with voltmeter battery reads 12.8 volts. Any ideas... Thanks...
Old 01-18-2005, 02:34 PM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Re: No electrical power...
Does the vehicle start? Sounds like a bad fuse. Check the power box under the hood first, pull each fuse and check for corrosion, use a multimeter to read resistance. If it isn't shorted (less than 100 ohms) then it's bad.
Also, check the battery connection, remove corrosion, ensure good contact between cables and battery posts.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
Old 01-18-2005, 04:07 PM
tdi_nitoxdiver tdi_nitoxdiver is offline
Re: Re: No electrical power...
After your reply i went back to check the battery connection and after removing the battery cables found corrosion around the battery posts. I removed the corrosion and removed dirt inside the battery cable terminals and problem fixed!!!. Thanks for the help!!!
