Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-15-2005, 04:17 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Warped brake rotor??
Alright so now (since yesterday) my front left brakes seem to squeel but not a solid squeel, something more like a rotating squeel, louder then softer, and i have not a clue what happened to it. It started after some dumbass cut me off, saw i was close to his bumper and hit the brakes, i didn't lock up or even brake that hard, but thats when i noticed it started happening. the weather has been really cold (around 15 degrees fahrenheit) and i'll go through occasional sluch puddles but i'm wondering if maybe the rotor is warped or if thats a possibility since i only have 10k miles on my car
thanks
Don't act like you don't love it.
503/2000
Old 01-15-2005, 06:46 PM
Stickin_It_2_Em's Avatar
Stickin_It_2_Em Stickin_It_2_Em is offline
Banned
Re: Warped brake rotor??
There might be a smallrock i the pads. Pull the caliper, and check out the pads.
Old 01-15-2005, 07:20 PM
dickswhip00gs dickswhip00gs is offline
if im not mistaken, hot metal has a tendancy to warp, or become brittle when it it is suddenly cooled. so .......
Old 01-15-2005, 08:36 PM
Sleepr awd's Avatar
i will pop the wheel off and check the pad then, and check the rotor for ice on it, i guess if its warped its time to save for an upgrade
503/2000
Old 01-16-2005, 03:28 AM
Banned
It only costs like $10 to get the rotors turned if you take them in. Its a well worth investment!
Old 01-16-2005, 04:10 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
There is no way that ice will be on your rotor, even under the mildest stop, your rotors get warm. If they are newer rotors, and were broken in properly, warping shouldnt be an issue, and you would be able to feel it in the pedal and your steering wheel would shake under braking. But, a small rock from a slush puddle would make sense. you might not even have to take the whole unit apart, just get some hot water (since its cold out), and flush the caliper with it...it might clear it...if not then take it apart and check.
Old 01-16-2005, 09:26 AM
hows yer search for brake calipers going?
Old 01-18-2005, 10:25 PM
Sleepr awd's Avatar
haven't had free time to check it yet, but its pissing me off i've just been turning up the music and ignoring it and downshifting mroe to slow down than braking
btw i heard something about "retreading" the tires anyone got an estimate price on that, the flat spot is kickin' my butt on the highway
503/2000
Old 01-19-2005, 02:28 AM
rodbls's Avatar
Dude, if you have a flat spot its cause your tire is out of ballance. I doubt you will want to retread that because the flat spot on your tire will have less rubber after retreading than the other part of it. I would say if you are short on cash buy 2 tires (fronts probably) and make sure they are ballanced good.
Old 01-19-2005, 03:46 PM
Sleepr awd's Avatar
i was wanting to buy a couple sumitomo tires (cheap and good performance) but i'll have to see how much the tax return is before i can make any committments and i'm still waiting on my W-2's but that is a good plan and i'll try to scrape my money to get some
503/2000
