Old 01-15-2005, 03:49 PM
chuckeieio chuckeieio is offline
Door sensor removal?
on my 00z24 my door sensor pin has been seized to the closed posision and when pulled out manually needs lots of giggleing to make the lights turn on. I want to replace it. Now i ripped a lot of plastic out and still found this part to be unaccessible to me. Has anyone attempted to remove this and been succesful?
The Haynes repair manual makes no refrence to this as usual.
Do tell.
thanks.
Old 01-15-2005, 05:19 PM
planedude planedude is offline
Re: Door sensor removal?
I'm pretty sure they just pop out. then the pigtail pulls out through to unplug..
Old 01-15-2005, 08:03 PM
Re: Re: Door sensor removal?
No way! Damn! I always try to do things the hard way. If it's that easy then i thank you my friend. It's like -10C here so the rubber is probably really hard.(If that's what's holding it in). I'll try it tomorrow in the garage and post the results.
Thanks a lot.
Old 01-16-2005, 09:18 PM
This thing is as tight as a mo fo! . should i keep tearing on this thing?
Old 01-17-2005, 09:15 AM
are u prying on the whole plasric piece that fits in the metal or just the pin?
Old 01-17-2005, 09:56 AM
Whole plastic piece starting from the steel door. there appears to be a gromet there. I'm gonna give it another try in a bit. it has been sitting in the garage and has since warmed up a little
Old 01-17-2005, 11:38 AM
OK! success! The switch has a plastic extrusion on each end which allows it to be pushed in innitially, butprevents it from being pulled out. It came loose with a SNAP!! and the wings holding it in snapped off. I guess that's the only way. Now i called Crappy tire and every other parts store here in scarborough trying to find one to replace it with. It turns out the only place to get it is at GM. So as my bad luck goes, akk GM computers are having a problem today and cannot locate one or gimee a price. go figure! Oh well, i'm on the right path now.
Thanks everyone
