Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-15-2005, 02:40 PM
Sputnik13 Sputnik13 is offline
Wheel hub bearing assembly
Is it true that the wheel hub bearing cannot be repaired and needs the have the whole assembly replaced with 2000 models? Somehow I feel like I got myself ripped off by going to the dealer for this, but I don't know any good mechanics where I am.
Old 01-15-2005, 02:56 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Wheel hub bearing assembly
yes it is true. they cost about $140.
Old 01-15-2005, 02:58 PM
blazee's Avatar
Problem?
If you have any mechanical experience you can do it yourself. I just did mine last week. There is a lot of info on this in the blazer forum.
Old 01-15-2005, 03:14 PM
So they weren't lying about it having to be replaced but I did get ripped off for parts... I'm paying something like 700 for the whole repair. Well, I guess that's just a lesson learned.
Old 01-15-2005, 03:45 PM
blazee's Avatar
Problem?
Ouch! You must have a 2wd...I forgot they are more expensive. Up to $500 for the assembly depending on where you get it.
Old 01-18-2005, 12:29 AM
2wd is more expensive? no, I have 4wd, and the parts were expensive because I went to the dealer.
Old 01-18-2005, 10:23 AM
blazee's Avatar
Problem?
Yes 2wd is alot more expensive. $700 for a 4wd you got screwed. When you go in to pay....have them put some of the extra grease on your butt so it doesn't hurt so bad.
Old 01-20-2005, 12:04 PM
ArnzCardz ArnzCardz is offline
Is this something I should be worried about? Does it happen certain years? I have a 99 with 62,000 miles. Does it happen in certain climates? Thanks in advance.
Old 01-20-2005, 01:05 PM
I don't think you need to worry about it unless you have the symptoms. If you do have problems with it, don't go to the dealer like I did.
Old 01-20-2005, 03:38 PM
blazee's Avatar
Problem?
You shouldn't worry about it. Yes alot of people have had to change theirs, but the symtoms will be obvious and you can change it before it becomes a hazard to you or your truck. Here are the symtoms:
Humming accompanied by a vibration
It gets worse when you turn in one direction
goes away when you turn the other way.
Old 01-21-2005, 05:26 AM
GeneP GeneP is offline
They ain't hard to replace. I did both sides on my 2000 Sonoma. The only special tool was a cheap puller to pull the hub off the shaft and I had to purchase the metric socket for the hub (Don't remeber the size). The hubs were $100 each at a local parts house.
I did drive the truck several thousand miles with the growling without problems before I replaced them.
Gene
Old 01-21-2005, 07:31 AM
blazee's Avatar
Problem?
They're $140.00 each for the Blazer,Jimmy, and Bravada.
The Socket is a deep well 36mm (most places charge $15- $20 for the socket)
You will also need an 18mm for the hub bolts. (A 3/4 SAE will work but has a little slop if the bolts are tight you may damage the head.
