Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 01-15-2005, 01:41 PM
Wister06 Wister06 is offline
Send a message via AIM to Wister06
Would u Recommend Skunk 2 or Nex coilovers???
I was wondering if anyone could help me narrow down my decision between skunk 2 coilovers or Nex???
I have heard many good things about both products but i was wondering if anyone had any experiance with them???
With how they ride and how my perform!!!
Old 01-15-2005, 01:54 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
You can't really compare Skunk's and Nex's since the skunks are just the adjustable spring (mount your own shock/strut), while Nex's are the full damper assembly.
Old 01-15-2005, 02:04 PM
Re: Would u Recommend Skunk 2 or Nex coilovers???
would u say that nex's are a good coilover system???
Old 01-15-2005, 02:12 PM
SiGNAL748's Avatar
I couldn't tell you from firsthand experience, but i've done a bit of research on them online. So far i've heard no complaints about them.
Old 01-15-2005, 02:13 PM
thank you what have you used to lower your ride if you have lowered it?
Old 01-19-2005, 08:18 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
Why do you want coilovers so bad. Is adjustability that important to you. A good set of springs is also a great way to go. The Skunk2 coilovers do not have as stiff spring rates as other coilovers. The RS*R Race Springs are stiffer than the Skunk2 coilovers and Neuspeed Race Springs are even stiffer than the RS*R's. Do some more research and look at spring rates and how much the suspension lowers your car. You should use that to decide what suspension you want.
