4 1/4" Lift Q's?
If I get a set of 1 1/4" lift shackles and a set of 3" extra long add-a-leafs what else would I need besides longer shocks? Would I have to have brake line ext.s or would I have to lower the transfer case or anything like that? My Jeeps a 93 Wrangler with no lift yet.
Re: 4 1/4" Lift Q's?
It all depends. You may need longer lines, or you may not. You probably will need the t-case drop, or someother way to correct the driveline angles...but, you may not.
No two Jeeps are exactly the same, so there's really no way for someone to say what your's specifically will need. You can put the lift on, then see what you need. |
Ok thanks I just wanted to make sure nothing super critical was going to be needed. I'm just looking for a quick and economical way to stop my tires from rubbing and I heard a body lift wasn't the way to go.
