Old 01-15-2005, 12:09 PM
jribbe1 jribbe1 is offline
Send a message via AIM to jribbe1
building a box for 2 10" Punch's
Hi everyone i need a bit of help. I am looking to build a box for 2 rockford fosgate 10" punch subwoofers. I am going to make it sealed not ported and each woofer in its own chamber. I went to the rockford fosgate website and the little box calculator said i needed to make it
hieght 10"
Depth 12"
width 14"
for each chamber to make it for .65 cubic feet of airspace. The woofers are P110S4 Models
now does that mean that that is the internal measurements? If so how do I know what the external measurements will be. Thanks for the help
Old 01-15-2005, 02:35 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: building a box for 2 10" Punch's
I'd suggest porting them for extra loudness and better low end.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 01-16-2005, 01:20 AM
Johannes Johannes is offline
Banned
Ported is an option, but in the manual those subs say to use 0.65 cf sealed.
When you take those dimensions you gave it gives a volume of approx. 0.97 cubic ft... and if you subtract 3/4" from each side (I'm assuming that's the thickness you'll be using) then it's 0.65 cubic ft. I guess it would be a little less because of the displacement of the sub...
So it sounds like those measurements you got are for the external part of the box.
Old 01-16-2005, 12:26 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
If everyone did everything manuals said the would of audio would be a shitty place....
Old 01-17-2005, 12:13 PM
Banned
Yeah that is true
Old 01-18-2005, 02:28 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
ditto.. port those little 10 inch bitches
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
