Old 01-15-2005, 11:08 AM
BigFig15 BigFig15 is offline
Send a message via AIM to BigFig15
Transmission Question
Last night I was driving around and I didnt have my performance shift on and when i was rolling like at 20 and I floored it, it didnt do anything for a second then it quickly accelerated. The second time i went past someones house stopped, put it in reverse tapped the gas and nothing happend for about a second then it went into reverse. Whats going on here?
Old 01-15-2005, 11:20 AM
Phoenix69 Phoenix69 is offline
Re: Transmission Question
That happened to me once, nothing happened, then it took off.
Old 01-15-2005, 07:10 PM
fopu fopu is offline
Maybe the fluid lost its properties. Check it and if it's brown or foamy, that's the problem. Anyway, don't change it if you never did it before. Just try to be gentle with the car from now on.
Old 01-16-2005, 01:37 AM
I just got it flushed like a month ago and it shifts smoothly. Ill have to take a look at the fluid.
Old 01-17-2005, 05:43 PM
I took a look at the transmission fluid and it looks normal. What do think is goin on?
Old 01-17-2005, 05:50 PM
gregfor1 gregfor1 is offline
did you check the fluid level, sounds as if its low, that could cause the hesitation. Remember to check on a level surface when the fluid is warm.
Old 01-17-2005, 08:35 PM
Yea the level was good. It had a nice red tint to it
Old 01-17-2005, 09:03 PM
troy1 troy1 is offline
AF -Advisor
so does the engine rev up?
Old 01-19-2005, 03:08 PM
Yea the engine revs up, I think its weird thing that happend that has no explanation
Old 01-19-2005, 06:57 PM
94sportsedan 94sportsedan is offline
Let's hope that tranny flush didn't do any nasty things, as they usually do. Seen several failures shortly after.
Old 01-21-2005, 02:29 PM
I remember reading a post about having to clean the transmission line. How much screwing around is that? Plus where I got it done he looked at the fluid first before he did anything and told me that it could use a tranny flush.
