Old 01-15-2005, 09:59 AM
eillob's Avatar
eillob eillob is offline
Radiator upgrade
My engine combo has far exceeded the ability of my stock radiator so its time to look for a better one. So if anyone has any input please let me know the best brand, maybe whos got the best deal.
Also will a 93 style aftermarket work and whats the difference between a 2 row and a 4 row, which is better?
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 01-15-2005, 10:55 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Radiator upgrade
I have had many different radiators. FMS brass 3 core, Fluidyne alum 3 core, and FMS heavy duty wide 2 core alum.
I didn't like the FMS brass, didn't really do and adequate job. The Fluidyne split on me, expensive set back, and the FMS alum ownz all! It is by far the best radiator I've tried yet.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-15-2005, 01:59 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
I like the Fluidyne alum 3 core but sometimes the fitmit was a bit tight. Like the bottom pegs was off by 1/2inch, so I ended up taking the rubber grommets off, which then made the radiator sit in the frame. Might or might not be a issue.
I would also suggest a electric water pump.
My ride at my site Silverstangs.
Old 01-15-2005, 02:21 PM
eillob's Avatar
The Fluidyne split? They gotta lot of nerve asking what they want for one of those for it to split. What did you end up doing did they offer to replace?
Silverstang why do you suggest an electric water pump were there fitment issues with the new radiator?
Old 01-15-2005, 09:31 PM
HiFlow5 0's Avatar
Stanger
My money was refunded in full from where I bought it.
-2013 Ford Flex
-1999 Ford F150
Old 01-16-2005, 02:03 AM
No fitment issues.......
But here are the reason's why..
The electric water pump maintains a costant flow of fluid that does not increase or decrease because of engine rpm. You can set the flow rate with a variable speed controller, so you can actually adjust the flow based on the needs of your engine. You can run your standard pulley's, because your gonna gain 10~18hp depending on RPM with the electric water pump.
With higher RPM's, you get cavitation, which decreases the amount of fluid being moved by the belt driven water pump. The electric ones don't have that issue.
The belt driven one can create enought flow to bust your heater core. The electric one's again are adjustable.
It's a stealthy mod, most people don't even see it.
Stick with the Meziere extreme duty pumps, the others are for the race track.
Old 01-16-2005, 06:54 AM
HiFlow5 0's Avatar
Stanger
Re: Re: Radiator upgrade
I would not suggest an electric water pump on a street driven car. No need for it.
-2013 Ford Flex
-1999 Ford F150
Old 01-16-2005, 09:25 AM
eillob's Avatar
I've kind of frowned on electric water pumps myself. I agree with Highflow I think there a little much for a steet car. Plus I've heard there hell on the cars electrical system but I appreciate your input. All the prices I've found for one are between $375 and $575. Is this about the going rate.
Can I get a 93 mustang radiator to fit in my 94?
Old 01-16-2005, 11:09 AM
It's not meant for everyone, just the hard core crazy people. We did dyno one which was a before and after dyno. The electric water pump went from 1-3hp more than the UD pulley and 2-4tq more than the ud pulleys. That was dependant on the rpms, and leveled off around 4500rpm. I would say that most people will see about 8hp from UD pulley's alone, and up to 12hp with a electric water pump alone on the modular engines. If anyone hit's a 18hp gain, then they probally had a water pump that was going bad and giving extra resistance, or they have a big block with a big water pump and impeller.
I used to frown on electric water pumps, but after installing several of them in different cars, they have changed my opinion.(all modular engines) As far as being hell on the electrical system, We didn't see any difference with the electrical system. It's around 7 maybe 8 amps max at full volume. Most aftermarket stereo amps pull more juice. Most people won't even run the pump at full volume, and I think we was a bit closer to about 50%~60% of the max flow rate. The coolant was cooler according to the infra red thermonitor, about 12 degrees cooler at idle.
I have not see any electric water pump for less than $350 that was designed specifically for a car. I have seen "Universal" ones that can be bought for less than $250. There is a new one that is out that I am thinking about trying. It's made by a company called Davis Craig. They make a EWP that is a little cheaper than the other companies. The issue is that they are using a "Universal" design, but it can run continuous.
http://www.daviescraig.com.au/main/display.asp?pid=8
I don't really like universals, I prefer something specifialy designed for a application, but I do like to try different things to see how they work. Besides, if I don't experiment, who will.
Old 01-16-2005, 11:13 AM
I would say yes.... but I would suggest you measure the post under the radiator. They stick into the frame when the radiator is sitting in the car. I also don't remember if the 94's had the degas tank on top like the 99+ modular's do. But then again, it might be like the V6 mustangs.
Old 01-17-2005, 07:30 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I picked up a Griffin Aluminum universal fit, 31" x 19" for like $190 from Summit. 2 row, 1 inch tubes. Cools great! Fit almost perfect w/ some mild mods to the upper brackets. I'm not sure if the style is different from fox's to sn's, but either way good bang for the buck.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 01-17-2005, 07:44 PM
eillob's Avatar
Well I found an AFCO universal radiator for about $180. I didn't know griffin made a universal or I would have gotten it. O well I'll take some pics when its finished and let everyone know how it turned out.
Old 01-18-2005, 06:45 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Hey man, search on the corral, there's been a few guys who have done universal and fox radiators in SN95s and there are a few good threads with some good instructions and pics.
I went with a fluidyne, it bolted in and no problems (yet, 6 months, 5000 miles). I have heard others complain of a fluidyne splitting, but I've also heard of others having excellent luck.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 01-18-2005, 07:19 PM
eillob's Avatar
Thanks man I'll check it out.
Old 01-19-2005, 05:41 PM
eillob's Avatar
Hey, the AFCO radiator arrived today. Very impressed with the quality of this tank. I'll take pics before I get started. Looks like the AC is going bye, bye I dont think there will be room for both the new radiator and the AC radiator. I guess thats the price you pay for performance.
