Old 01-15-2005, 03:03 AM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
Breathers..
For the air breathers, will they even fit our cars..? not too sure..
1991 Dodge Stealth R/t
Old 01-15-2005, 11:03 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
You lost me on that one
Resistance Is Futile (If < 1ohm)
Old 01-15-2005, 01:35 PM
Hotshot8792 Hotshot8792 is offline
i think he means those breather filters that you put on your valve cover to catch the oil so it doesnt recirculate back into your intake piping.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-15-2005, 05:35 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
well you can always change your PCV valve. but if your really worried about oil from the valve covers circulating into your intake, then 3sxperformance has an oil catch tank--> 2 actually, one by Greddy, the other from Cusco (http://www.3sxperformance.com/engine.asp). However, i remember that Erik Gross made an oil catch can out of parts readily available for fairly cheap. here's his site: http://www.team3s.com/~egross/3S/Mod...MCC/index.html . In addition to stealth316.com, Erik Gross' page at team3s.com is very helpful as well: http://www.team3s.com/~egross/.
After reading his page, its actually a Crankcase breather oil catch can instead of a valve cover oil catch can.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
