Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-15-2005, 02:06 AM
DONALD MURRAY DONALD MURRAY is offline
Question 240sx problem with boost
I have 89 240sx with sr20det red top.with skyline turbo upgraded manifold,external wastegate. OK problem car sputter-brakesup when boost gauge reads more than 8 pounds of boost.does car need a fuel cut defensor to run good.thank you for any information
Old 01-15-2005, 02:27 AM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: 240sx problem with boost
ok, he's either drunk or high.. nobody types like that sober or clean
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 01-15-2005, 01:47 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Sounds like the spark is blowing out. Gap your spark plugs down a little.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 01-15-2005, 02:58 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
did u upgread the fuel pump? sounds like it can't keep up?
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 01-25-2005, 09:55 PM
Re: Re: 240sx problem with boost
thanks for info i replaced fuel pump and turned the boost down for now untill i install a fuel cut defensor
Old 01-25-2005, 10:05 PM
D-Bo's Avatar
got any pics of replacing the fuel pump??
Old 01-25-2005, 10:31 PM
Mayday0017 Mayday0017 is offline
you need help changing your fuel pump? it takes like all of 20 min. If you need instructions PM me.
Old 01-25-2005, 11:59 PM
240SX Guy
You don't need a fuel cut defenser. Ever hear of people getting a boost controller and running 14psi stock? Yea thats not the problem. Pull your plugs, clean them, and gap them down to like .030". Worst case scenario, you are sure it isn't your plugs.
-Cory
12.6@122mph
Old 01-26-2005, 12:27 AM
TatII TatII is offline
i think having a clogged fuel filter, etc would also cause the car to break up on top. so yeah have your plugs checked, and change the fuel filter.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 01-26-2005, 11:09 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
The Skyline Turbo is nothing the SR cant handle... its actually has a smaller A/R than the S15 T28. you didnt list a upgraded fuel pump so get one quick The 240SX can barely handle a T25 on 7psi so theres your problem
