Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 01-15-2005, 01:19 AM
stevewo72 stevewo72 is offline
help me with my 4x4 electronic problem
When i press the 4x4 button, the 4x4 doesnt engage. The previous owner said it might be a relay or something wrong with the electronics down in the transfer case. Any knowledge?
Thanks in Advance....
[email protected]
Old 01-16-2005, 05:14 AM
mazdatech mazdatech is offline
Re: help me with my 4x4 electrical problem
your auto hubs are broke(most commonly happenes when brakes are replaced, they get forced on big no-no) or your change motor is bad if you take off your frt wheel is their little retatainer clips on your lugnuts or do your hubs just slide off?
Old 01-16-2005, 01:11 PM
Re: Re: help me with my 4x4 electrical problem
Ill check that by taking off the front wheels. Do i have to replace the entire auto lock hubs if the clips are broken? The previous owner said that the motor might be bad also.
thanks
Old 01-16-2005, 10:36 PM
If what I sent you helps than you should post it here for others to see. I would, but I'm not sure how to. good luck
Old 01-17-2005, 12:06 AM
ok. i had a mechanic friend of mine check the hub it was fine, checked relays in the engine department and it was fine, checked the switch to see if it was fine and the transfer motor.
steve
what else could it be?
Old 01-17-2005, 03:12 AM
did you check it like i said.... lift it in the air(all four tires off the ground) and try to engage the four wheel drive what happens?(and how did your buddy check the frt hubs?)
Old 01-30-2005, 07:21 PM
rpenny rpenny is offline
Have you checked the Actuater in the front differential. My brother had the same problems with his truck and that's what it turned out to be. Good Luck.
Old 02-01-2005, 12:20 AM
Dont waste your breate rpenny he hasn't even let me know anything that i suggested. he is lazy and unappreciatated.
