Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 01-15-2005, 12:50 AM
Jet805 Jet805 is offline
Send a message via AIM to Jet805 Send a message via MSN to Jet805
87 Civic overheating problems
I'm currently driving a 87 civic with carb. I'm pretty sure the car gives false heat readings because it says i'm running in the red when the heater isnt even that hot. I also noticed some strange noise today it sounded like bubbles somewhere around my battery. The noise was also noticable inside the car and with the hood open. So my guess was that its a hose, my batt, or the radiator. If you know anything that could help me please reply.
Old 01-15-2005, 01:27 PM
KrisSmithRocks's Avatar
KrisSmithRocks KrisSmithRocks is offline
Send a message via AIM to KrisSmithRocks
you don't have any or at least very much coolant in the car. Check the coolant level first then since you got it hot. I'd do a compression check on all of the cylinders and make sure they are pretty close to each other.
89 Honda Accord LXi 2dr- Daily driver SOLD (sniff sniff)
89 ED CRV... soon to come GSR head, ARP studs top and bottom, T3/T4 at about 6psi ... it's quick...
89 ED DOHC ZC
Old 01-15-2005, 07:48 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: 87 Civic overheating problems
lxndr is right. with my old motor i was losing coolant from a bad head gasket and when it was really low the engine would be super hot but the heater wouldn't put out any heat. basically there isn't enough coolant to reach the heater hose.
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 01-15-2005, 07:52 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: Re: 87 Civic overheating problems
HA! That wasn't me! But yea, that sounds right.
Good assessment KrisSmithRocks!
