another frozen fuel line question
I've got a 92 Civic. I live in MN, and today we had a HIGH of -2 degrees. I started the car this morning to heat it up. It started fine but there was, and has been for a long time when starting in cold weather, almost like a quiet whine. It tapers off and disapears as the engine catches and idles up, lasting only a few seconds normally. This morning that whine lasted longer than usual, and when I came back out to leave, the car had died. If the car started ok and then died a few minutes later, could it be a frozen line, or would it just not start in the first place? Also, anyone know what that whine might be? It doesn't sound at all like a belt, more muffled. Fuel pump? Oil and fluids are fine. New timing belt, water pump, head gasket. Always has been a reliable cold starter. Just old?
Re: another frozen fuel line question
hmm... I honestly cant really tell you what that would be. But, you could test your theory of frozen fuel lines with a bottle of Heat for the fuel.
![]() LS1 RX-7 Zoom Zoom |
Take care and Happy Holidays!! AK_Virgo_75m |
gasoline has a very low freezing point...................-140 or something like that. if it froze, it would be like hell freezing over. water in the fuel maybe that froze? thats what causes most fuel lines to bust in the cold. theres a product called heat. pour it in and if theres water in the lines, it will evaporate. follow the manufacturers instructions. other than that. check for fuel and spark. check the fuel pump and main relay.
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
Re: Re: another frozen fuel line question
Take Care, AkVirgo_75m |
i recently had a problem similar to that with my 92 hatch, the car would run for a little while then finally conk out, it was running really well then over the period of a few months the idle started to get rougher and then the problem with turning over and cutting off began. the whine i heard was the fuel pump, even the brand new one i had whines worse than my daughter. the fuel pump being mounted in the tank under your back seat is usually the reason why you hear it. i went on leave for 2 weeks in october and returned to find my car wouldn't start at all, i replaced the fuel pump and the car fired up without hesitation. a fuel pump ran me 89 dollars at auto zone, and was a relatively easy part to change with the help of a haynes manual (also sold there.) to change the fuel pump id say maybe a 2 hour job tops if you are at a beginner level like i am
92 civic dx hatch aka the money pit just another u.s. army paratrooper |
