Old 01-14-2005, 10:56 PM
89cavalier 89cavalier is offline
Starting in winter
Hi I have a '89 Cavalier 2.0 L fuel injected. I had my car running on Wednesday (the 12th), but it sat outside for Thursday in -37 C, -50 C (with windchill) weather. On Friday morning I tried boosting it but it wouldn't turn over. (It cranks but doesn't want to fire up). The interior lights come on so the battery must still have some juice. I was thinking that the battery is just too cold/some cells are frozen or possibly the starter is going. Anyone have any ideas or advice?
P.S. I am planned to take out the battery and warm it up inside for awhile can anyone tell me the easier and safest way to do so?
Thanks for your time,
Nathan
Old 01-14-2005, 11:40 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: Starting in winter
first off it has nothing to with wether or not the battery is warm or not - lol
Are you gettin fuel outa the injectors check em make sure they are spittin fuel when u try an turn the engine over u will need two people for this... also check your spark if you want me to explain how to do that let me know .... if not try those 2 an then let me know whats goin on
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 01-15-2005, 12:36 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Rock a bye battery on the charge cycle,
When the current flows you get a charge,
but when your charge dosn't hold, I think somthing is wrong... down goes the battery to the auto parts store...
.. You might want to take its temperature while your at it...
god damn.. why not just wrap it up in an electric blanket in your engine bay.
sorry but i had to let that out. Your fuel lines could have become frozen due to condensation in them. Try putting the whole car in a heated garage. My gurls cav did this last winter.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-15-2005, 12:39 AM
LMFAO Ya can't be more blunt than that
Old 01-15-2005, 03:03 PM
Here in Canada we have a season called winter where it is not uncommon for the temperature to remain at -35 C for days. (not taking into consideration the windchill). You don't think that will have an effect on a battery? Last year my roommate had to remove his battery and warm it up inside as the cells were frozen. Obviously if I had access to a electrical plugin I would have plugged in the block heater, and I don't have a battery warmer.
Old 01-15-2005, 03:13 PM
planedude planedude is offline
see if you can hear your fuel pump running when you cycle the key. Some gasline antifreeze might help....
Old 01-19-2005, 11:09 PM
What does/should the fuel pump sound like? I think the pump is in my gas tank on my car.
Old 01-20-2005, 06:24 PM
if u take off the gas cap you can hear it better. Just sounds like a humming and should be there for 3 seconds when you turn the key ahead to ACC position.
Old 01-21-2005, 05:40 AM
cousincletus cousincletus is offline
I had the same problem. The car would start and run if I used ether, but wouldn't start on its own. The problem on mine was the coolant temp sensor.
Old 01-21-2005, 09:40 PM
noshun's Avatar
noshun noshun is offline
Re: Re: Starting in winter
I'm up in Canada too. ON. By the Way, Wind Chill doesn't affect your car! It just breaks thru the invisible layer of insulation your body naturally creates thus "it's -35 but FEELS like -50". Your fuel line has Frozen , would put money on it! Get some of the Red Fule line anitfreeze from crappy tire, it's about $5/$6 for 8 applications although you'll need to get the car somehwere warm enough to thaw what's frozen! Good Luck!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-23-2005, 04:25 AM
melissa2000's Avatar
melissa2000 melissa2000 is offline
Yeah it kinda sucks to start the car in minus 50..lol...push the clutch and it just stays pushed in.....my car starts pretty good..even not plugged in all nite..probably pretty rough on it though. I just got it a week ago and finally figured out i was plugging in the fan to heat the inside of the car instead of the block heater...lol..:S Oh well got er all figured out now...now that its warmer...
Old 01-24-2005, 11:54 PM
Re: Re: Re: Starting in winter
Ya i would have to agree or just add some to his info - its been only about -15 here past few weeks - an thats been enough to freeze peoples lines i have seen it alot in the last week, but what also could be happening is the moisture in the gas tank could be freezin up an the little pieces of ice that are bobbin around in ur Gas tank are cloggin up the fuel filter an not allowing fuel to get through......
good luck with the car - i bet ya wish ya had a garage for times like this- 35 is cold - not fun to be out workin on cars in that temp... bundle up buddy
