Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 01-14-2005, 10:42 PM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
tune up questions
it's about time my frankencar needs to be tuned up...
question though, first time tuneup on an import car (used to domestics)
how do you get to the spark plugs on the engine? it looks strange compared to the ford's i was used to.
that
and
what spark plugs are recommended? i want some good ones, like the ones that can produce better performance...
also, any tips on anyone who has done this before? anything will help a bunch.
Old 01-16-2005, 03:26 PM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Re: tune up questions
you mean the j-30 car?
opcorn:
Old 01-16-2005, 08:03 PM
Registered User
yea, my 93 j30t
Old 01-17-2005, 01:35 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Originally Posted by Underground_Killah
it's about time my frankencar needs to be tuned up... it looks strange compared to the ford's i was used to.
I bet u have individual coils for each plug, compared to coil+distributor. Pull them off, plugs are as used to: use never bosch...
Harness PM http://www.cardomain.com/memberpage/748507/14
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-19-2005, 11:47 AM
infinman infinman is offline
1.change plugs ngk pfr5g-11 works best
2.renew fuel filter
3.renew air filter
4.remove snorkels from throttle body and clean backside of throttle plates.These throttle plates after time collect deposits on the backside.These deposits eventually prevent the throttle plates from completely closing thus affecting tps signal return and closed throttle switch monitoring.
4.do not attempt timing adjustment.
Every two years you must have a fuel system cleaning{proper}done.Making sure the air plenum is cleaned as well.This ensures the valves don't become too coked{carboned}.
Old 01-27-2005, 02:41 AM
Registered User
i appreciate it... any idea on a pcv valve?
Old 02-04-2005, 05:28 AM
Re: Re: tune up questions
- PCV. Have problems? If you have a rubber tube from it, pinch it closed for test purposes. First loosen rubberhose from valve cover.
- TPS is a potentiometer that wears out, at Throttle Body axle. Tst and/or replace. One may also drill a hole on the TPS box and soak/clean the worn resistor with electronics cleaner. http://www.cardomain.com/memberpage/748507/6
- KS= knock sensor? ...most probably bad already. ECU retards ignition if KS is bad, power loss, fuel consumption goes up 15%. When high octane gas tank full, install a susbstitute resistor on its connector: http://www.cardomain.com/memberpage/748507/9
...or just replace KS.
- Plugs: I bough the extra expensive platinum plugs cause their lifetime promise is 6x std. Actually comes cheaper, and no replacement works.
Old 02-07-2005, 10:49 PM
Registered User
yea i got bosch platinum +4's... they are working niiiice for me
