Old 01-14-2005, 08:24 PM
99eclipsegst 99eclipsegst is offline
Post Boosting Problems...Help Needed
i just upgraded my bov to the Greddy type-s and the intercooler piping was also upgraded. After installing both i made sure to check that everthing was connected right. I took the car for a test run and it wouldn't boost over 5 psi.
What could be causing the problem?
Also, the elbow to the intake manifold was very hot.
thnx for the help in advance
1999 Eclipse GST
Mod List: T-25, greddy boost controller, k&N intake, Apex'i Exhaust, Boost Gauge, Greddy BOV, Greddy IC Piping, Dump Tube Mod, Symborski Shifter Kit, B&M Short Throw Shifter, Turbo Timer, and Apex'i DP.
Future Mods: Evo III with supporting mods in 2-3 months .
[IMG][/IMG][IMG][img]
Old 01-14-2005, 08:31 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Boosting Problems...Help Needed
boost leak. make the tester on vfaq.com and check for leaks. my guess is that either the bov floange or the intake pipeconnections are leaking. did the bov have a gasket for the flange?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-14-2005, 09:44 PM
Yes the bov does have a gasket.
But, would a boost leak cause the elbow to the intake manifold to get really hot?
1999 Eclipse GST
Old 01-14-2005, 09:55 PM
it could depending on where the leak is. if its at the throttle body then the air being pushed out there could heat it up. since the turbo still managed to get 5 psi with a leak that means it was definately pushing much more air then usual. more air leaking out means more heat.
-1stGenRocks-
Old 01-14-2005, 10:04 PM
thanks for the help. ill check tomorrow for air leaks. if i have anymore questions ill post tomorrow.
1999 Eclipse GST
