Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-14-2005, 08:48 PM
artin64 artin64 is offline
Question where is Throttle Position Sensor at?
hi, guys i was wondering if anyone had a pic of where the Throttle Position Sensor is located, on a 2002 maxima. i have a pic of a 99 one but it is not the same place for the 2002 or if it is i cant find it.
well if any one can help please leave a message.
thanx
Old 01-15-2005, 01:19 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: where is Throttle Position Sensor at?
thanx
Typically the TPS is in the end of TB axle, Throttle Body controls intake tubing airflow.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-15-2005, 01:49 AM
ok thnax, i found the TPS, but the sensor is sealed and there are no screws to open. it is just seald in a plastic box. do u guys know how to check and see if Tps is working correctly? or should i just replace it?
Old 01-15-2005, 10:32 AM
Re: Re: where is Throttle Position Sensor at?
There are switches plus potentiometer. See the 'craptons' online manual if it gives the specs for u model. At my web page no1 is the link... Potentiometer should have linear response, thats more important than aboslute reading.
For TPS innards see: http://www.cardomain.com/memberpage/748507/6
If u suspect it, I would drill/punch with solder iron a hole and squeeze liberally contact cleaner in. Let it flow down and dry, test. If ok, would not buy new.
But tst other sensors also.
Old 01-15-2005, 02:37 PM
infinman infinman is offline
Question
1.Why do you want to replace {or mess with} the TPS.
2.What kind of emission warranty do you have.In Canada it's 5 years.
BTW. don't drill holes in any sensor
Old 01-15-2005, 02:54 PM
well the thing is that i dont want to make any holse, the only thing is that i want to make sure that it is not working proply so i would change the whole thing. o by the way there is a small screw at the bottom of the TPS that i have no idea what it doest. couild that be for tuning the TPS, i mean may be the new models are like that. I jusdt want to fix this problem no matter what it is driving me crazy.
Old 01-15-2005, 06:37 PM
What problem are you having?
Old 01-15-2005, 06:55 PM
the one and only problem taht i have with this car is that when im going 30m or more when i push the gas pedal down, instead of lowshifting and going faster, the rmp just keeps going up from 3k slowly. sometimes it works and sometimes it just doesnt. also when it is workig, with the car stopped, i can feel that with just a little bit of push on the gas pedal the car pulls forward (it is like the pedal is harder when it is working right). but when it is not working correctly i have to push harder and the rpm has to go higher until ill get to the speed that i was getting before with a little pressure on the gas pedal.
Old 01-17-2005, 02:30 AM
I could figure out that they have added potentiometer zero pos adjustment as they used to be all wrong from beginning...
Just replace TPS, relatively cheap.
Coil packs cracked?
Try autozone.com, log in and seek if u can get your model service manual. It describes all sensors, how to tst.
You can also go to dealer and ask only for sesnors test, would not be too costly. Limit their job just to diag, stand beside and watch. Pay, thanks, leave and decide whattodo... Then buy u self what they suggest and try replacing.
read: http://www.cardomain.com/memberpage/748507/14
Old 01-17-2005, 02:39 AM
well i took the car to dealer, they said that i need to replace my AFM and an o2 sensor. i asked for price they said around 700 box, i thought i would show it to my mechanik first. i took the car to my mechanik he cleared the ECU and checked again, no more codes. i know why it was showing the AFM sensor cuase i opened the intake to clean the engine and turned the car on without putting the wires back.(i forgot) so i know my AFM has no problem, and i dont get the o2 code either. and everytime i go to dealer they charge me 100 box just for going there. that is the reason why i dont take the car to dealer anymore.
Old 01-17-2005, 07:45 AM
U have so new car that it would be real bad luck to have sensors broken. Was the original 'problem' cause the ECU warn light/codes?
Quite universally on all cars: taking batt off for some time clears ECU. Batt neg cable off should be always the first job, also if take seats etc. off (with airbags).
New ECU's need one week to collect data to get inspection through: we are riding towards big bro system.
Me - never use dealer ship: I am capable of sinking my ship myself...free. But that dealers serviceman who is not capable of first (or second)clearing ECU, what can I say? Hopefully just an individual, but leaving a car on dealers mercy means always big bill, lots new parts (or the serviceman take em for blk market) at least charged.
They tell in the news that quite possibly the airbags will vanish during 'maintenance' - who of us really knows if currently still have airbags or just air without bags?
Old 01-17-2005, 01:26 PM
i totaly agree with u, and that is why im searching in all these forums, i dont trust the dealers anymore. o and i foudn this website http://www.technosquareinc.com/350reset.htm
it show how to Accelerator Pedal Release Position Learning and Throttle Valve Closed Position Learning i going to try themsee what will happen, ill keep u guys informed.
Old 01-17-2005, 01:49 PM
Isn't that process for their own ECU, not for the original Nissan?
Anyways, I've an oldie 3L and that will not help me.
Old 01-17-2005, 01:54 PM
no i think it is for 2002+ maximas, the ecu reseting i already knew, but the other two i have no idea what they do, so im going to give them a try todya see what will happen.
Old 01-18-2005, 02:48 AM
ILOVEMY69 ILOVEMY69 is offline
Send a message via AIM to ILOVEMY69
if you have a cold air intake there might be something wrong w/your o2 sensor because those go out a lot otherwise there shouldn't be anything wrong with it. Also you can read your own trouble codes without a scanner. If you need more info, just ask.
-Eddie
1969 chevy nova sb 350
1995 Nissan Maxima totalled 8/11/04
