Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-14-2005, 08:46 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Need someone with a 94 4.0L attention.
I need some of you out there who has 93/94 4.0L in there ZJ or XJ, to check out the placement of the Rotor with the #1 piston at TDC on the compression stroke.
let me know if the Rotor is exactly on #1 (on the cap) or slightly behind or what?
thanx fellas.
Old 01-15-2005, 06:09 AM
Cam7 Cam7 is offline
My 93 XJ 4.0 is just about dead on #1 on the cap. If you are setting the Dist. it wont always go exactly to # 1 it might be a little off do to the oil pump. You will be able to tell if you got it right when it is set in.
Old 01-15-2005, 06:17 AM
Re: Need someone with a 94 4.0L attention.
thanks Cam, I am trying to help someone with there distributor problem. He took his distributor off to replace the Camshaft Position Sensor, and he thought he marked eveything, well anyways he got it all put back together and now he says it idles but won't go above 1000 rpms, I don't think it's a timing problem, but he wanted to be exact on the location of the rotor.
thanx Cam.
Old 01-15-2005, 06:44 AM
carpotts carpotts is offline
i dont know about the 94 edxctly but the 4.0 are all almost identical and the timing is controled by the ecu try pulling the dist. and going back a tooth i had same prob
Old 01-15-2005, 06:48 AM
OK I will have hi try that.
You had the same problem with it idling but won't go above 1000 RPMs?
Old 01-16-2005, 05:34 AM
Sounds like its a tooth out. Go to TDC on #1 and check the Dist position on the cap. If it isnt right on #1 it is out a tooth.
Old 01-16-2005, 11:07 AM
he said when it's at TDC (on the compression stroke) it's exacly on the #1 Cylinder on the cap (he wanted to be sure it didn't have to be behind the #1 or what. I told him to pull it and turn the rotor back one tooth, I am awaiting his response.
