Old 01-14-2005, 05:25 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Post IAC how to find/clean/remove/replace
no the IAC (Idle Air Control) valve or the or the IAB (Idle air bypass) -- what the IAC is an electrically-operated valve which allows air to bypass the throttle plate in a fuel injected engine to regulate engine idle speed. And if not working properly it will make your idle go frantic or should i say raise an lower with out compressing the throttle. In this age of fuel injection, idle problems can literally be caused by hundreds of different things. When your car is new the IAC works remarkably well. The problem arises when the car gets some miles on it (usually 75K+) and carbon fouling takes its toll.
What happens is dirt, excess air filter oil, and most notably carbon gunks up the IAC valve and doesn't allow it to either open or close properly. This can cause an really high idle, a lumpy/surging idle or no idle at all. The solution is to either replace or clean the IAC.
you should have no trouble finding yours. They all look basically the same
Removing the IAC:
This part is simple. The IAC has an electrical plug that needs to be disconnected (picture 2 "C") Then all you have to do is remove the two bolts (Picture 2 "A") that hold the IAC to the throttle body or intake. Watch out for the IAC motor to throttle body gasket, don't lose it!
Cleaning:
Next all you do is use the carb cleaner to clean the carbon out of both of the holes (picture 3 "C") in the IAC valve and both of the holes in the intake/throttle body.
Putting it back together:
A self explanatory step. Put the IAC in place and install/tighten the bolts. Make sure you don't forget to reinstall the gasket.
Fire her up!
Finally you need to start the car and let it run for a few minutes to burn any leftover carb cleaner in the intake. You may have to crank the engine a little more than normal to start it for the first time and don't worry about the white puff of smoke you see coming from the exhaust because again it's just the carb cleaner.
Good Luck!
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 01-14-2005, 06:16 PM
godenm's Avatar
godenm godenm is offline
Re: IAC how to find/clean/remove/replace
there may be a few people here that wont be able to find it on a cavalier cause that looks wat different on a gm
Old 01-14-2005, 10:51 PM
well it was just for a reference - an the AIC is always located in the same spot. so people will still be able to find it an know how to clean it - thats all i was goin for... that is description is off a ford
I will post cavy parts i just couldnt find them on my computer i know we have pics of it
Old 01-14-2005, 11:25 PM
K
Here is a better look for people that need exact visual of what they are lookin for - Good call godenm
diagram
On A Ecotec Engine
A better look @ it on the throttle body
What it looks like off
what it looks like with the valve an the motor seperated an cleaned
hows that godenm? look a lil better - lol
Old 01-15-2005, 08:04 AM
godenm's Avatar
good pics. if no one can find it know,then they need to give up!!!!
Old 01-16-2005, 01:03 AM
thanks - lol ya that should sure as hell help - can't get more optical about it then that- unless ya take the part out an throw it at em or physically point it on in person
