Old 01-14-2005, 03:20 PM
a91civic a91civic is offline
Dizzy Q?
My winter civic died the other day while I was driving it just stalled out and would not start. I am thinking it is the dizzy because I am not seing any spark, I pulled it out, and the rotator screw is there, but the rotor does not spin freely is that normal?
I bought the car for $500 and was told that it had new plugs, wires, cap, and timing belt. So i would not think it would be the timing belt (at least I hope not!)
Old 01-14-2005, 03:25 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Dizzy Q?
Just stalled out hmmm....Its not the timing belt-or at least i think its not. When a timing belt breaks its usually pretty loud-when valves interfer with pistons.
Well if it just stalled out and wont spark hmm? Not sure about the rotor but check the plug wires that there in tightley, and that you have enough gas-i did that!
Sorry cant help much more
Old 01-14-2005, 03:30 PM
I was going about thirty in fourth gear and it stalled so I dropped into second to drop start it and that did not work so I pulled to the side of the road, all the wires are in tight it turns over but does not fire at all.
Old 01-14-2005, 03:41 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Dizzy Q?
coil?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-14-2005, 04:07 PM
Well I am off to the local auto store to pick up a ignition coil, $75.99.
Hopefully that will be the problem...
Old 01-14-2005, 04:08 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: Dizzy Q?
we had an 88 accord that just died one day while going 40mph. it turned out to be the timing belt. but i think it's rare that it just died with no noises or any other signs than staright loosing power.
to be sure there is no spark there is a simple test you can do. pull out a spark plug and ground it (you can do so by having it touch the valve cover). then have somebody crank your car while you watch for spark. no spark means it's your ignitor or coil within the dizzy or the dizzy it's self is bad.
what do you mean by not spin freely? the rotor should spin, but not exactly freely. by not spinning freely do you mean it's not spinning at all?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-14-2005, 04:10 PM
amy@af's Avatar
Re: Re: Re: Dizzy Q?
you also need to check grounds. we once did a swap and 1 ground wasn't tightened all the way. jer went to take it for a test drive...i dunno if he hit a bump or what but 2 blocks down he called me on the cell saying the car lost power and to bring tools. it turned out to be the loose ground
Old 01-14-2005, 04:44 PM
Re: Dizzy Q?
hmmm might be the t-belt. When my friends t-tbelt broke it was loud. Hmm take off the valve cover and you'll see real quick if its the timing belt! Just pop out those spark plug wires and its like 6 or so 10mm bolts.-dont tighten them tight either! Then take a look at the cam!
Old 01-14-2005, 05:11 PM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: Dizzy Q?
on my old 1990 civic my dizzy went out as i was driving and it kinda felt like i ran out off gas. as for it turning free, no it does not turn freely.
Old 01-14-2005, 05:17 PM
I got the new ingition coil on the dizzy now I get to go out is the freezing cold and reinstall the dizzy, hopfully it will be fixed!
Old 01-14-2005, 05:45 PM
Got the ignition coil on and it was a no go. losened the timing belt cover and the timing belt does not appear to be broke,the belt does seem tight. but I don't think it is turning??? the belt does seem tight. cant tell from inside the car, i need another person here!
Old 01-14-2005, 07:03 PM
CBURKE's Avatar
Re: Dizzy Q?
GET A NEW DIZZY, they are knowen for going out in these car's.
