Old 01-14-2005, 01:22 PM
paulfischer paulfischer is offline
check engine light
I recently replaced my IAC on my 99 lumina w/ 3.8.
And now the check engine light comes on. But it only comes on when I put it into park after its been driven. When in gear it idles fine, and even when its in park it idles fine.
Any thoughts???
Thanks
Old 01-14-2005, 02:20 PM
fopu fopu is offline
Re: check engine light
Have you tried to scan it for codes? This will take you one step closer to solving the problem
Old 01-14-2005, 03:15 PM
not yet..
hopefully this weekend..... going to call autozone to see if they pull the codes..
Old 01-17-2005, 06:10 PM
autozone pulled the code. said high idle.
what would cause a IAC valve to have a high idle??
Thanks
Old 01-17-2005, 08:34 PM
cadgear's Avatar
cadgear cadgear is offline
Did you ensure the pintle wasn't more than 1 1/8th inch extended before installing? Did you do the 10second on, 10 second off initialization?
And it is possible to get a bad IAC. If its an off-brand/aftermarket you probably got one. A customer brought in their 1993 olds with a stalling problem...checked the IAC, it had literally disassembled itself inside the bore. Customer said it was only 1 week old, offbrand.
Old 01-18-2005, 05:09 AM
The brand is Wells.
I did measure the length of the bintle, and it was the same as the old one that came out. I will recheck to make sure that its 11/8th of an inch. If its longer or shorter, how does one change the length.
Yes I did the 10 second on, and 10 second off procedure.
Thanks again!!!
Old 01-18-2005, 05:21 PM
cadgear's Avatar
Wiggle the pintle around while pushing in with moderate pressure.
Check the wiring as well, ensure nothing's broken or bad connections anywheres.
Old 01-18-2005, 08:54 PM
is wells an off brand???
I will be checking the pintle in the am. and if no luck with the length, will be putting old one back in, and going to dealer to get a GM part.
