Old 01-14-2005, 12:22 PM
toyotawolf762 toyotawolf762 is offline
bent valves?
ive got a 91 z24 with the 3.1 i bought it as is ,was told it needed a timing chain so i figured no big deal,put a new one on and car still wont start ,,find out all the intake pushrods are bent or broke...replaced them and still no start..no compression..is it possible valves got bent...and if thats the case would the pistons still be ok...engine has 200km on it...any help would be great
Old 01-14-2005, 05:54 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: bent valves?
it is very possible that the valves did get bent - because that is alot of strain on an engine when a rod breaks an is still tryin to function. Have you checked an made sure the timing was correct? - are you gettin spark ? are you gettin fuel from the injectors?
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 01-14-2005, 08:13 PM
Re: bent valves?
timing is set right on..cam at 6 and crank at 12..gettin fuel and spark...
Old 01-28-2005, 10:53 PM
noshun's Avatar
noshun noshun is offline
Re: Re: bent valves?
Had the timing chain broken? I would imagaine so going by what you posted, then at least one piston has hit a valve and that will more or less destroy the valves and will damage the pistons too. If it wont start if all the pushrods were broken then the lifters and valves are probably busted too.
I had to go into your profile to find this post.
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
