Old 01-14-2005, 12:05 PM
Arkountryboy Arkountryboy is offline
Horn
My daughters 2000 cavalier's horn quit working. There is a clicking under the dash. Is this a relay? If so will this solve the problem? thanks.
Old 01-14-2005, 05:51 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: Horn
that would be the relay - but being a newer car the relay shouldnt of went on it unless the person was a frantic horn user - city driving or something - did u check the conection on the horn itself - make sure that it was still wired ?
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 01-16-2005, 12:46 AM
z24 fanatic z24 fanatic is offline
Send a message via AIM to z24 fanatic
Re: Horn
or if she hit enough water i went through a puddle too fast and water got in the horn and it was makeing the same sound until the horn dried out
Old 01-16-2005, 12:48 AM
Re: Horn
ya but - that has to be a good amount of water to do that - anything is possible i guess lol
Old 01-28-2005, 11:58 PM
safetyguy safetyguy is offline
Re: Re: Horn
have a 2000 cav...my horn is dead too. The fuse is fine, the relay is fine. THe relay in my car is located on the drivers side of the car, under the left side of the dash. It is a small black rectangular piece. Mine was taped with electrical tape to a small bundle of wire. You have to look for it, but it is there. Oh, if you need another, don't bother with any auto parts stores, they wont have it, just go to a GM dealer, Its about $5. But, if it is clicking, most likely the relay is good and something else is wrong. I replaced my relay, but it did not fix the problem. SInce the relay clikcs, that means the horn button on the stearing wheel works, so that leaves only the horn. THe horn is located on the right side, behind the bumper, IF you crawl under the car on that side you will be able to see it. Good luck!
Old 01-29-2005, 10:20 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Horn
^^ Ditto
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-29-2005, 10:46 AM
Re: Horn
lol why u quoting me to that safety guy?
but yes i said if its not the relay just check the horn it self .......
Old 01-29-2005, 06:45 PM
IFIXCARZ4U IFIXCARZ4U is offline
9 times out of 10 it is the horn itself and yes it is usually caused by water entering the horn. just use a 12 volt testlight at the horn connector if it lights up when u hit the horn button the replace the horn
