Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-14-2005, 12:48 AM
skidder04 skidder04 is offline
Send a message via Yahoo to skidder04
88 prelude 2.0s engine/fuel delivery problem
To any one who might be able to help me my prelude is 88 2.0s how do i tell if it fuel injected throttle body or carburated? please feel free to email me the problem im having is the vehicle will start wont stay running but you have to give if it full throttle for it to start. i have put in a new fuel filter and pump. any help on what i can check thanxs
Old 01-14-2005, 01:00 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
Re: 88 prelude 2.0s engine/fuel delivery problem
the 2.0s has a Dual Sidedraft Constant Velocity carb. and you have already done the obvious.. fuel pump, and fuel filter. best I can tell you is to pull out the carb, and start cleaning.. using carb cleaner, toothbrush. can also get the fuel lines replaced as there might be a clog in the lines, but you can check this with a fuel pressure guage. as long as the carb is getting fuel pressure it's not your fuel system.. probably a bad sensor somewhere.. could be a plethora of things on a car that old.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
