Old 01-13-2005, 10:48 PM
BlazinUP BlazinUP is offline
wheel bearings...at what mileage did u replace them?
iv a 93 s10........4x4 with 145k.
im hearing a low groan at speeds 30-50...then it goes away...
iv had this sound on another high millage car and it was the wheel bearings..........
i was wondering if anyone else had this problem...and at what mileage.
also about how much did it cost in a 4x4 s10?
Old 01-14-2005, 02:10 AM
OverBoardProject OverBoardProject is offline
Banned
Re: wheel bearings...at what millage did u replace them?
It's best to just re-pack them whenever you do the brakes. Use the proper grease and it'll last for a long while.
If you drive through really dusty roads, or flooded area's you should re-pack them more often.
And everyone in California that's driving through those 18" deep puddles should get theirs done as soon as it dries up there
Old 01-14-2005, 02:14 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You cannot repack 4x4 s10 wheel bearings.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-14-2005, 09:41 PM
well thats an answer...........to another question...
how bout the first one
Old 01-15-2005, 01:44 AM
BlazerLT's Avatar
AF -Advisor
Could be the bearings being bad or the front differential needs a oil change.
Old 01-15-2005, 07:15 AM
had the diffs front back....done before the winter.
had this sound before and after....just seems to be there.....verry low...not high pitched, groan/werrrrr
sound.
Old 01-15-2005, 12:24 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
I've had the sound too for about a year and a half, and I'm pretty sure it's bearings. It's just not bad enough that I'd do anything about it.
Old 01-15-2005, 07:31 PM
to change the bearings....is it harder or more $$ because its a 4x4....do you need to do anythin else beside the bearings?
Old 01-15-2005, 10:25 PM
BlazerLT's Avatar
AF -Advisor
You can't just replace the bearings, you have to replace the whole hub.
Old 01-15-2005, 10:36 PM
have any idea of how much that runs?
Old 01-15-2005, 11:08 PM
BlazerLT's Avatar
AF -Advisor
I don't have pricing here, but call your local parts store.
Old 01-16-2005, 06:12 AM
blazee's Avatar
blazee blazee is offline
Problem?
The signs of a wheel bearing problem are:
Noise from the affected side
Vibration
While turning in one direction it gets worse, when turning the other direction it goes away.(unless they are both going out)
It should be about $80
Old 01-16-2005, 02:24 PM
BlazerLT's Avatar
AF -Advisor
Minimum price $110
http://www.partsamerica.com/SelectPa...aring%2C+Front
Old 01-16-2005, 03:21 PM
blazee's Avatar
Problem?
Re: Re: wheel bearings...at what millage did u replace them?
Originally Posted by BlazerLT
You're right. I didn't notice it was a blazer. I looked up S-10 pick-up at autozone.com.
Autozone only shows one for S-10 pickup it is the W/O ABS for $80
They show s-10 blazer with ABS for $130
Partsamerica.com shows all of them with a choice between ABS and without. ranging between $72 - $128
Blazinup,
I replaced mine at 115,00
Old 01-16-2005, 06:58 PM
s10bajadan s10bajadan is offline
Smile Re: wheel bearings...at what millage did u replace them?
I releplaced my last one at 129k.Its more $$ if its got ABS...
