Test Pipe Pain
lolz
Re: Test Pipe Pain
bu,mpmphghj
Re: Test Pipe Pain
Are you letting the PB blaster soak overnight? Also use a breaker bar, or something long to give you that extra leverage.
Also if you do a search, there was a thread quite a while ago that had a true 3" testpipe for around $60. Ebay testpipes are usually 2.75", but you can find them for $30.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Test Pipe Pain
What is a breaker bar exactally?
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Re: Test Pipe Pain
just a pipe or something that you can slip onto the end of a wrench to make hte handle longer...this gives you more torque to break the bolts free.
Re: Re: Test Pipe Pain
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: Test Pipe Pain
Oh...haha, you learn something new everyday...I just always used my craftsman 1/2" with a lead pipe.
Re: Test Pipe Pain
doesn't 3sxperformance.com sell top notch pipes for around $40? I remember getting a testpipe when I still had my old 3kgt but it was from bob at 3si.org so I'm not sure if the prices would be the same for either.
i bought my test pipe off e-bay from user performanceexhaust. here is one of his auctions http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW for the 3/S. He includes two exhaust gaskets. very good quality part; i was quite happy with it. easy 15 minute installation...provided you can get the rusted bolts off. As Igovert said, definitely let the PB blaster (or whatever rust penetrant you're using) soak overnight. Then spray the bolts again. Then put some elbow grease into it. its nice to have a friend to help you: he can hold the wrench on the head of the bolt while you turn the ratchet on the nut side of the bolt. if no luck, then just put the ratchet (make sure its the 1/2" drive) perpendicular to the car, and push it with your foot. of course you can kick it, but as the car is up on jack stands or a jack, i wouldn't recommend it.
Re: Test Pipe Pain
[/url]
