Old 01-13-2005, 09:25 PM
tigerdevil tigerdevil is offline
Question Problems with a 92 RS
Hey, Im new here but im gonna give it a try.
I have a 1992 Camaro RS with a 3.1 V6. I have been having problems with it lately. I can get the car to start and it will run for a while(times very) After running it for a while or driving it for a while the car just dies. I do not know why. I have already replaced plugs, distributor cap, rotor, ignition coil. I have had the ignition module tested but nothing seems to be working. If anyone might know what is up i would greatly appreciate the help.
Thank You.
Old 01-14-2005, 03:45 AM
Morley Morley is offline
Check the fuel pressure while driving, tape a FP gauge to the windshield and monitor the pressure. If it drops jst before the engine dies the pump needs to be replaced. If the pump checks good, replace the ignition module with an AC Delco one.
Old 01-14-2005, 01:48 PM
I had the module tested and everything is in proper working order. I will look into the fuel pump, and get back. Thanks
Old 01-14-2005, 05:27 PM
Re: Problems with a 92 RS
A little secret about ignition modules...if they check bad they are bad...if they check good, they can still be bad.
Old 01-15-2005, 10:36 AM
Im having the module looked at again, and it is also at a shop having the codes read and looked at. i will post what is going on.
thanx
Old 01-17-2005, 01:21 PM
I just got a call from my garage today. They said that it is a pick-up coil in the distributor, and will cost about 250 to 300 total, and only 100 for the part. Anyone know of a good place that i could get one for cheaper??
Old 01-17-2005, 05:09 PM
We have discovered the problem with the camaro. It was the pick-up coil in the distributor. So we are replacing that and the beast will be running in a matter of days, (cuz im a little busy) Thanks to all who gave me ideas though
Old 01-18-2005, 05:07 PM
Krypt0's Avatar
Krypt0 Krypt0 is offline
I replaced my whole distributor for $100. Got it from Orielly's. Sounds like your getting ripped. It would take them maybe 20 minutes to replace it. Another 10 to set the timing. Sounds pretty steep.
1992 Camaro RS - 5.0L 305 V8
Flowmaster Exhaust, K&N Filter, Redline Water Wetter
Hypertech 160 Powerstat w/ 177-166 Fan Switch
245/50/16 Kuhmo Tires on 16" ASA Wheels
JVC KD300 CD/MP3 Player
Old 02-11-2005, 02:56 PM
89bonnevil 89bonnevil is offline
nick your a moron
your cars fine now,,,except for the dent in the door!!!
jeremy
