Is a fuel rail flush necessary?
Is flushing the fuel system a good thing to do? ...From a preventative maintainance point of view? ...Does it save you money in the long run?
First off, I don't know if I Throttle Body FI or individual injectors... If I don't have individual injectors should I just go with the basic TB cleaning approach or is there some additional benefit by doing the full fuel rail flush (using an in-line approach)? My '97 Blazer has 115K miles on it and it runs fine (16 city, 19 hwy). First off, my VIN # is |
Re: Is a fuel rail flush necessary?
Additonal info: My VIN# 1GNDT13W5VK213530
Can anyone tell me what fuel system I have based on the engine code listed in my VIN? |
from what I see your VIN is a "w". I am pretty positive the W is a cpi which is one injector. I have a Z which is a tbi which is 2 injectors.
Re: Re: Is a fuel rail flush necessary?
Question: How can you tell what type of fuel injection system you have by looking at the engine? Question: Has any felt their mis-fires or other problems were solved by doing a fuel rail cleaning? ...or is this just marketing? |
Central Sequential Fuel Injection On regulator, six injectors. Run a fuel injector cleaner treatment through it if you want to clean it.
1995 Factory Blazer Service Manual for sale, PM if interested. |
ok than I stand corrected. my owners manual says that w is cpi but I guess due to the newer age for your vehicle I guess they changed it.
no, it is CSFI
TBI = ended in 1995 CPI = ended in 1995 since 1996, they all have been CSFI.
Thanks again... Can you tell what type of system you have by looking at the engine? Note: Behind the TB is an unusual device with electrical leads going to it. The other end looks like it goes into the manifold. Is this part of the Fuel injection system? ....Just asking. I'm thinking that it is. Anyway, if I do have a CSFI (with 6 injectors) can you confirm I need to do the whole fuel rail cleaning and not just a TB cleaning??? |
the way to verify by looking at your engine is to check how many injectors you do in fact have. But if Blazer LT says that you have all 6 than you do in fact have all 6. To check your injectors you would need to pull off the plenum and I believe you should eb able to see them than. I may be wrong since I don't touch a fuel system in my vehicle. But I am pretty sure that is what you do by me watching this forum I have gained a lot of knowledge I will not use soemtimes. But it will eventually help me.
Re: Re: Re: Is a fuel rail flush necessary?
If not, just run a fuel injector treatment through it.
mine is a 01 blazer and I have a tbi system, I heard that they went back to it for fuel mileage
Maybe the 2.2 has tbi, but all 4.3's have the csfi 96 on.
Except I can't remember if vin z's were something different. I know w is csfi. |
Both Are CSFI, there are NO TBI 4.3's after 1995.
What about the 2.2?
