Old 01-13-2005, 08:46 PM
j-mill j-mill is offline
Exclamation Starting Problems
ok i just installed a new fuel pump on my 92 s-10 blazer and now when i try to start it it cranks over but it wont fire up and none of my acces. will turn on so i dunno what to do i would like to get some information on this issue
Old 01-13-2005, 09:07 PM
jsgold jsgold is offline
You are not listing a lot of information. Why did you replace fuel pump? Not starting before I assume. Did you run pressure test before or after new pump. Did you replace fuel filter? Did you verify spark? I just wasted $200 replacing a fuel pump over the holidays because I did neither. thought the engine was firing, but it was not firing enough to run... Turns out I had a bad ignition module which is at the base of the distributor. Replaced distributor and coil. Now runs great. (the truck would "hit" with starting fluid, so I thought the thing was OK as far as ignition was concerned). Bought myself a fuel pressure tester first thing after fixing. If you check pressure and absolutley know the spark is OK, your problem could be the injector assy. the thing I don't understand is why no acces. running. you mean radio and so forth???
Old 01-14-2005, 04:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Starting Problems
CPI or TBI engine?
1995 Factory Blazer Service Manual for sale, PM if interested.
