Old 01-13-2005, 08:15 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
ZC distributor
wondering what i have to do to get my car to run right seems as if its having firing problems but not throwing any codes....wondering cause i swap everything from my d16 to my new zc sohc non vtec...do i have to get a diff dizzy to make it run right caseu i think my timing 180 off?
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 01-13-2005, 09:39 PM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
Check to make sure you have the plug wires on the right plugs. Check the firing order.
90 Civic Si Turbo ZC
Old 01-13-2005, 10:23 PM
Re: ZC distributor
how it says put it on number 1 cylinder on dizzy oi go plug it in with motor top dead center and it dont go in...if i put it on number 4 on dizzy it slips right in ever had that problem?
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 01-14-2005, 11:26 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
are you sure its at top dead center? u might have the motor 180 degrees off and not the dizzy. then check the firing order on the cap and make sure thats right.
Old 01-14-2005, 12:47 PM
fast2camciv's Avatar
fast2camciv fast2camciv is offline
is it just me or..but doesnt the dizzy only go on one way? i mean the cam is keyed so that the dizzy only goes in one way. so sounds like timing is off, maybe a tooth or two (check your timing with a timing gun) or your spark plug wires are off, sounds more like timing though.
Old 01-15-2005, 09:37 PM
Re: ZC distributor
well my zc poor at take off then it runs like a champ once it gets going is that all lead to timing?...cause right now i have it firing at cylinder 4 start the car
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 01-16-2005, 08:22 AM
Sikocivic's Avatar
Re: ZC distributor
Oh Hondas you can't put the dizzy in wrong. It has an off center slot in the end of the cam. It only goes in one way.
