Old 01-13-2005, 06:59 PM
bjunk10 bjunk10 is offline
96 Taurus Dome Light Stays On
My Taurus dome lights were staying on today. I lubed all the door latches / switches with WD-40. Solved the problem.... just thought I would post.... took a while for me to discover the solution.....
Old 01-14-2005, 06:13 PM
KimMG KimMG is offline
AF - Advisor
Re: 96 Taurus Dome Light Stays On
WD-40 is a water dispersal compound and will only work as a lubricant for a short time, then it will become gummy and attract dust. Lithium grease will last longer and it is also available in spray cans.
Old 01-15-2005, 08:07 AM
mwt mwt is offline
Someone should tell the folks at WD40 this and maybe they will shut down production.
Mike
Old 01-24-2005, 08:54 AM
Mac626's Avatar
Mac626 Mac626 is offline
I have a similar problem. When I examined the doors, I don't see any kind of switch like I'm used to seeing on other cars. Is it located behind the door panel or something?
Old 01-24-2005, 10:29 AM
iyadnubani iyadnubani is offline
Re: Re: 96 Taurus Dome Light Stays On
The switch is located on the door itself, inside the door latch.
Old 01-24-2005, 10:36 AM
Mac626's Avatar
Re: Re: Re: 96 Taurus Dome Light Stays On
Thanks - Do I need to remove the latch, or simply spray lubricant into it directly?
Old 01-24-2005, 01:34 PM
Just spray lubricant directly into it, you might need to do it more than once.
Old 01-24-2005, 06:39 PM
jcl27 jcl27 is offline
after spraying the wd 40 in the latches,slam each door 5 to 10 times
to completly work the lubrication to the switch.seems to work for the
real stubborn ones.
