Old 01-13-2005, 06:51 PM
3000-G_T_S_L 3000-G_T_S_L is offline
Send a message via AIM to 3000-G_T_S_L
Unhappy Parts Wanted
I have a 99 SL, and I've been looking for the factory front tag mount, and the left fog lamp. I can't seem to find them anywhere online or off. And the stealership wants way to much as usual. Please help if you can
1999 Pearl White 3000GT SL - Sold
1992 Dark Green 3000GT VR4 - Spun Bearing
2006 Black Suzuki Katana 600cc -hit from behind, totaled
*JUST BOUGHT*2008 Red Mitsubishi Lancer ES - planning
Old 01-13-2005, 07:14 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Parts Wanted
The fogs are diffent right?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 01-13-2005, 07:21 PM
how do you mean different?
Old 01-14-2005, 04:22 AM
6g72tt 6g72tt is offline
Re: Parts Wanted
i have one fog light but i dont now ill send you a picture just send me your e mail later
Old 01-15-2005, 02:44 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Parts Wanted
by the "factory front tag mount" i assume you mean the license plate mounting bracket? if so, then i think i have an extra one. i'll have to look for it tho.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-15-2005, 10:04 AM
I'm wanting the black plastic thing that the tag actually mounts to, then mounts to the car. Got that?
Old 01-15-2005, 04:52 PM
Linebckr49's Avatar
i have the metal bracket that actually mount onto the car. i do NOT have an extra black plastic tag mount. do you need the metal bracket as well, or just the plastic tag mount?
93 3000GT base
Old 01-15-2005, 06:38 PM
I need the actual black tag mount
