Old 01-13-2005, 05:16 PM
phantomskyy phantomskyy is offline
leaking transmission fluid 91 caravan
hubby noticed some drips of transmission fluid under the van,we have owned the van less then a week we are wondering if maybe just the pan was loose and needed to be tightened any enlightment would be super .Its a 3.3 6ltre
Old 01-13-2005, 05:26 PM
Re: leaking transmission fluid 91 caravan
oops my bad its a 92 lol shows how much i know lol
Old 01-13-2005, 11:00 PM
Maxpen Maxpen is offline
The problem maybe the clamps on the transmission hoses. They loosen up especially in cold and winter weather. Tighten them up and see if that stops the leakage.
Old 01-14-2005, 12:05 AM
nipsirc nipsirc is offline
Make sure it is the transmission that is leaking and not the oil pan. If it is, do a tranny service and replace the tranny gasket and filter while you're at it. If it is the motor oil pan leak, then you know what to do.
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Also, if anyone has used gaskets, because they should use silicone, while doing a filter change. The gaskets "WILL" leak. But yes, cooler lines, bottom pan, driver side axle seal and front pump o-ring is the common places. Hopefully you can pinpoint it easily And its not one of the "bad" spots...
Old 01-14-2005, 12:41 PM
tyavm i will post the result
