Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-13-2005, 05:53 PM
mcervi mcervi is offline
1990 T-bird LX won't start
I'll start by saying I don't do too much with car engines, so bear with me...
I have a 1990 T-bird LX, with 3.8L V6. The car doesn't turn over when I turn the key. The lights and auxilliaries come on, and I think I hear the fuel pump star, but the engine does not turn over.
I have replaced the solenoid? (mounted on the side, just behind the battery) and the ignition switch in the steering column.
I can start the car by manually shorting across the posts on the solenoid.
Any ideas on what to check next?
Thanks
Old 01-13-2005, 07:37 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 1990 T-bird LX won't start
Check the transmission range switch. This switch allows the car to start in park or neutral only. I don't know where on your year car this is located but check around the shift linkage on the transmission to find it.
Old 01-13-2005, 08:01 PM
J_ROC812004 J_ROC812004 is offline
Send a message via Yahoo to J_ROC812004
yay the sounds like a fun one good luck
