Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-13-2005, 04:24 PM
UncleBenRep UncleBenRep is offline
Send a message via AIM to UncleBenRep
rb question
i was looking through some rb info and came across where a guy stated that the rb26 is just a bored and stroked rb25. is that true??? so would it be safe to say that you would bore a 2.5 to a 2.6 and throw in some rb26 pistons and rods???? or is there a lot of different parts that go with it....because if it were feasible it would be a good way to go because after xxx,xxx miles you should bore your engine to make it straight and true again and a rb25 clip is cheaper than the 2.6.....just curious thnks
Old 01-13-2005, 06:06 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: rb question
where did you read this? i hope it wasn't the rb faq.. if it wasn;t then check it out.. i'm pretty sure there's enough of a difference that you can't swap pistons
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 01-13-2005, 07:24 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
Re: rb question
and the fact that one is a TT and the other is just single turbo.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 01-13-2005, 07:39 PM
thegladhatter's Avatar
thegladhatter thegladhatter is offline
Re: rb question
The RB26 is twin turbo but is basically the same block. It HAS a different crank shaft allowing for more displacement. I believe the bore is the same. The same is true for the RB28 and RB30.
Mr. Congeniality and PROUD Infidel!
Old 01-13-2005, 08:42 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Re: rb question
^ Right-o... most if not all RB's have the same block... just different internals! BTW: They have stroker kits for RB25's to 2.6 liters and RB26's to 2.8 liters... cool stuff.
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 01-13-2005, 09:05 PM
Re: rb question
duh i know rb26 is TT....besides the main differences how much different are they, because i dont think that nissan would drastically change the 25 and 26. so your saying that the pistons are the same size just difference in crankshaft....rods too? another question....if you have crank and rods from a 2.6 and fit it in the 2.5 wouldnt taht be considered the 2.6 "stroker kit"???
Old 01-13-2005, 09:16 PM
Re: rb question
Yep. You would also need a different head.
Old 01-13-2005, 09:49 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: rb question
not to knock the knowledge of the peeps here in the s13 forum...but if you want some actual serious info..a good guy to go to is RazorGTR in the skyline thread...very very knowlagable about the skyline motors...he knows just about everything
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 01-13-2005, 09:54 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Re: rb question
Biggest difference between RB25 and RB26 is the head, different valvetrain and RB26 has individual throttle bodies and better intake manifold (or maniflow as a cashier where I work says), anyways, RB25+stroker is not RB26 like SR20DET+stroker is not KA24.
