Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-13-2005, 03:24 PM
TacomaPilot's Avatar
TacomaPilot TacomaPilot is offline
2003 Washer Fluid Change
I need to change the washer fluid in my 2003 Rodeo from the standard fluid to something that won't freeze in the Denver climate. Does anyone know how to drain out the existing fluid without running the washer fluid motor? The tank appears to be between the fender and the inner engine compartment wall. I already changed it on my Tacoma with no problems, just pulled the hose from the connection below the tank and let it drain, but I don't see that on this one, don't even see the tank. Is there an additive that can be added safely?
Old 01-13-2005, 03:25 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2003 Washer Fluid Change
Isn't normal blue fluid rated to like -40?
You could do the washer motor for a bit and top it off with the new stuff too.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-13-2005, 05:57 PM
mospeed1 mospeed1 is offline
Send a message via AIM to mospeed1
you can try to siphon it out with a small hose and a hand pump
dont forget about the rear tank also
02 rodeo ls
old ride 95 200sx full showcar
Old 01-13-2005, 08:25 PM
rodeo02 rodeo02 is offline
Why the resistance to running it dry???? You can run those pumps dry for a LOOOOONG time before they will burn out. Hold the washer/mister on until it starts pumping, add the washer fluid of choice & press the washer/mister button until it starts flowing.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-13-2005, 09:46 PM
Isuzu Guy
Is there one? I have an Amigo with a hard top and my rear washer pulls fluid from the front.
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-14-2005, 10:48 AM
Re: Re: 2003 Washer Fluid Change
The 1998+ rodeos only have one tank as well. It's plumbed all the way to the back for the rear window/washer.
Joel
Old 01-14-2005, 02:43 PM
Re: Re: Re: 2003 Washer Fluid Change
Joel
your right
my fault
02 rodeo ls
