Old 01-13-2005, 04:02 PM
95cord 95cord is offline
b16a2 into 89 crx
i read the 4th gen FAQ and it said to swap a b16 into a crx you have to buy a motor mount kit where can i get a kit? also does any one know if it requires any elec. changes? i have the ecu and and wiring harness out of the 99 civic si the engine came out of nay info would be great thanks
Old 01-13-2005, 04:53 PM
Hybrid1990crx's Avatar
Re: b16a2 into 89 crx
you can get kits off ebay and get one from www.hasport.com and since you have a 99 si motor i believe that is obd2 so you will have to convert from obdo to obd2. you can either do it yourself or you can also get conversion harness' on ebay.
Old 01-14-2005, 12:17 AM
2CrX's Avatar
2CrX 2CrX is offline
I you are using the tranny that came with the motor you will also have to conver to hydraulic instead of cable.
