I am new here so I will try and explain as clear as posible my problem. I have 1993 Rodeo with a 1995 motor.
Recently I changed the oil and replaced it with 10-30w when the motor was turned on the oil light came on for about 2-3 seconds while the oil lubricated the engine. Well after this the SUV ran perfectly and still does but about three weeks ago it started making a clanking noise, sometimes, the noise only happens when in iddle, the oil preasure is fine and the oil level is correct. The noise comes and goes. When the car is turned on be it hot or cold it will not sound but after running it a while it starts again when in iddle. So I took it to my mechanic he could not find anything he said that the motor was responding and sounding nicely. So I took it to another mechanic which told me it must be the crankshaft bearings. But my question is would this not have caused failure long ago of the engine? What is the problem? The sound comes from under the engine area. Any help would be appreciated. |
Re: Noise coming from Somwhere???
lifter tick?
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Both mechanics said no. Plus it sounds really loud when in iddle it will sound and when I accelerate the sound will get faster but go away quickly.
Sounds like your timing belt tensioner is going bad.
2000 VW New Beetle TDI 2007 Honda CR-V |
oops.
yup this sounds like a classic case of timing belt tensor knock. Some mechcanics misdignos it for rod knock. I can remember a couple of cases when the mech. was just about ready to yank the engine and replace it and the n the owner does some research on the web and find out that the engine is fine.
Re: Re: Noise coming from Somwhere???
Re: Re: Re: Noise coming from Somwhere???
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Re: Re: Re: Re: Noise coming from Somwhere???
Thanks for the help I will take it to the mechanic tomorrow. |
