Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-13-2005, 03:12 PM
kris_iugirl kris_iugirl is offline
Unhappy 98 neon leaking oil
I was wondering if anyone knows about neons. I have a 98 neon that I had for a year now and it is now leaking oil pretty badly. It just started doing this in the middle of November. I put oil in it about every 2-3 weeks. I went to a mechanic and he said my head gasket is broken but I really don't believe him especially if he wants $1200. Can any one help me out and possibly tell me what is wrong.
Old 01-13-2005, 03:41 PM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Re: 98 neon leaking oil
It is usually the head gasket on neons, it is a common problem.
Old 01-14-2005, 11:33 PM
wafrederick wafrederick is offline
Banned
The mechanic that checked it out is right.It is a headgasket,It is a common problem and most auto parts stores stock the headgaskets.It is the same engine in Dodge Stratuses, in some mini vans with the same headgasket problems.
Old 02-05-2005, 05:31 PM
WILL-I-AM WILL-I-AM is offline
Send a message via MSN to WILL-I-AM Send a message via Yahoo to WILL-I-AM
It Is The Head Gasket Thats Leaking The Oil....you May Also Need To Change The Valve Cover Gasket....if That Mechanic Is Charging That Much...go Some Where Else I Had Mine Fixed For Almost $600 Dollars(almost 600 With Tax) Search Around For The Better Deal
Old 02-07-2005, 07:33 PM
hinea hinea is offline
Re: Re: 98 neon leaking oil
Hi Will-I-am, i have the same problem with my 97 dodge neon. where did you go for $600.00?
Old 02-27-2005, 09:40 AM
fxspider fxspider is offline
98 Oil leak
Anyone with a oil leak on a Neon,Yes the Headgaskets go quite a bit,BUT also check the OIL sending unit located also on the back of the engine,Its a known problem for neons also,Mine was gushing out oil when the engine was running and also sprayed the bottom of my car making it difficult to locate...hope this helps........
Old 03-15-2005, 10:22 PM
Nerve Nerve is offline
I had a pretty bad oil leak and it was the rear oil seal (which is what I was told) and I had it replaced twice in 6 months.
